show ports transceiver information detail
show ports {port_list | tag tag} transceiver information detail
Description
Displays detailed information about the optical transceiver.
Syntax Description
port_list
Specifies the port number(s).
tag
Specifies an 802.1Q or 802.1ad tag value.
Default
N/A.
Usage Guidelines
Digital Diagnostic Monitoring Interface (DDMI) provides critical system information about the installed optical modules. Use this command to monitor the condition of XFP, SFP, and SFP+ optical transceiver modules.
The tag value may be associated with either a VMAN or a VLAN.
If you try to execute this command on one of the ports in the port list that is non-compliant with DDMI, the following error message is displayed and the command does not go through:
Port 3:1 This command is not supported on this port. All ports and transceiver of the ports requested in the command need to support DDMI.
If you try to execute this command on one of the ports in the port list on which the transceiver is non-compliant with DDMI, the following error message is displayed:
Port 3:1 This media/transceiver does not support enhanced digital diagnostic monitoring interface (DDMI). All ports and transceiver of the ports requested in the command need to support DDMI.
In Extended Edge Switching configurations, the transceiver information is obtained from the BPE ports only when an optic is inserted into the port and the values cannot be updated periodically. This is due to a limitation on the BPE.
# show port 2:* conf
Port Configuration Monitor                              Wed Sep 19 23:00:19 2012
Port     Virtual    Port  Link  Auto   Speed      Duplex   Flow  Load   Media
         router     State State Neg  Cfg Actual Cfg Actual Cntrl Master Pri Red
2:1      VR-Default  E      A   OFF 40000 40000 FULL FULL    SYM       %Q_UNKWN
2:2      VR-Default  E     NP   OFF 10000       FULL                    NONE
2:3      VR-Default  E     NP   OFF 10000       FULL                    NONE
2:4      VR-Default  E     NP   OFF 10000       FULL                    NONE
2:5      VR-Default  E      R   OFF 40000       FULL                    NONE
2:6      VR-Default  E     NP   OFF 10000       FULL                    NONE
2:7      VR-Default  E     NP   OFF 10000       FULL                    NONE
2:8      VR-Default  E     NP   OFF 10000       FULL                    NONE
2:9      VR-Default  E      R   OFF 40000       FULL                   %Q+LR4
2:10     VR-Default  E     NP   OFF 10000       FULL                    NONE
2:11     VR-Default  E     NP   OFF 10000       FULL                    NONE
2:12     VR-Default  E     NP   OFF 10000       FULL                    NONE
2:13     VR-Default  E      R   OFF 40000       FULL                   %Q+SR4
2:14     VR-Default  E     NP   OFF 10000       FULL                    NONE
      > indicates Port Display Name truncated past 8 characters
      Link State: A-Active, R-Ready, NP-Port Not Present, L-Loopback
      Port State: D-Disabled, E-Enabled
      Media: !/$/%/* - use "show port info detail" for more information
      0->Clear Counters  U->page up  D->page down ESC->exit
When a license is not installed, the restricted transceivers use a ‘$‘.
# show port 2:* conf no
Port Configuration
2:1      VR-Default  E      R   OFF 40000       FULL                   $Q+SR4
2:9      VR-Default  E      R   OFF 40000       FULL                   $Q+LR4
2:13     VR-Default  E      R   OFF 40000       FULL                   $Q+SR4
2:15     VR-Default  E     NP   OFF 10000       FULL                    NONE
2:16     VR-Default  E     NP   OFF 10000       FULL                    NONE
2:17     VR-Default  E      R   OFF 40000       FULL                    NONE
2:18     VR-Default  E     NP   OFF 10000       FULL                    NONE
2:19     VR-Default  E     NP   OFF 10000       FULL                    NONE
      Link State: A-Active, R-Ready, NP-Port not present, L-Loopback
# show port 2:1 info detail
Port:   2:1
        Virtual-router: VR-Default
        Type:           Q+SR4 ($ - Restricted Transceiver)
        Random Early drop:      Unsupported
        Admin state:    Enabled with  40G full-duplex
        Link State:     Ready (local fault)
        Link Ups:       1        Last: Wed Sep 05 04:38:19 2012
        Link Downs:     1        Last: Wed Sep 05 20:35:04 2012
# show port 2:9 info detail
Port:   2:9
        Type:           Q+LR4 (% - Unrestricted Transceiver)
        Type:           SF+_LR (! - Unsupported Transceiver)
        Admin state:    Enabled with  10G full-duplex
        Link State:     Ready
        Link Ups:       0        Last: --
        Link Downs:     0        Last: --
The following example displays the current status of non-Extreme optical devices:
show port 3 transceiver information detail
Port :  3
        Media Type             : Q+PSM4  (Licensed)         or
                                        (Unlicensed)       or
                                        (Restricted)
        Vendor Name            : NOTEXT,INC
        Part Number            : NOTEXT000EN-S001
        Serial Number          : NE7M90299
        Temp (Celsius)           :   0.00        Status                :   Low Alarm
            Low Warn Threshold   :   0.00        High Warn Threshold   :   0.00
            Low Alarm Threshold  :   0.00        High Alarm Threshold  :   0.00
        Voltage AUX-1/Vcc (Volts) :   0.00       Status                :   Low Alarm
        Tx Power (dBm)            : -inf          Status                :   Low Alarm
            Low Warn Threshold    : -inf          High Warn Threshold   : -inf
            Low Alarm Threshold   : -inf          High Alarm Threshold  : -inf
Press <SPACE> to continue or <Q> to quit:
In show ports transceiver information output, the Rx/Tx power values shown may be +/- 3dB from the actual value due to the limitation of SFP and the accuracy depends on SFP vendor. For accurate power measurement, it is recommended to use a power meter.
This command was first available in ExtremeXOS 12.4.
Support for the ExtremeSwitching switches was added in ExtremeXOS 12.5.
The tag value was added in ExtremeXOS 12.4.4.
Support for SFP and SFP+ optics was added in ExtremeXOS 12.5.3.
Show output was updated in 15.3.
Show output was updated to include the current status of non-Extreme optical devices in ExtremeXOS 15.5.
Platform Availability
